Old disker - question
   / Old disker - question #1
5stljayhawks
'71 MF 135
I'm a rookie.
Have access to an old disk 4"-6" sunk in the ground. On the front end(?) there is a saw blade looking thing, thinking adjusts the depth of the blades. Is this correct? On the back there is straight 1" pin hitch, is this for towing or adding addition disks, or something else?
I have pics if need requested.
   / Old disker - question #2
I'm sure you will get a quick response once you post photos.
   / Old disker - question #3
If there is a lever involved with the sawtooth thing then it will be to change the angle of the disks.
The hitch on back is more than likely for a set of harrows.:D
   / Old disker - question #4
The hitch at the back would be for a Drag or a EZ Flow spreader of some sort? Ken Sweet
378812 (A51573)
378812 (A51573)
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2019 JOHN DEERE 8295R LOT NUMBER 183 (A53084)
2019 JOHN DEERE...
