Old Diesel-Heads Going Gas
   / Old Diesel-Heads Going Gas #1
jayste
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
Well guys I thought I'd group this into one thread and hope it doesn't get shut down due to brand bashing. I know we can be rather "passionate" about our brands. I was wondering, of the current diesel pickup/truck owners out there, who was considering buying a gasser on your next truck purchase? Considering the normal maintenance costs of a diesel and the newer maintenance costs of the "EPA friendly" engines or, like me, you don't use it enough now to justify the costs. What are your thoughts? :anyone:
   / Old Diesel-Heads Going Gas #2
Not unless I run into some financial crisis. I'll keep my 6 year old Dodge Diesel.
   / Old Diesel-Heads Going Gas #3
I've got 2 diesels (F-350 & C-2500) both are used for pulling trailers. If I were to replace either, I'd still stick with diesel and replace the chevy (decent engine/tranny...everything else is junk). I've also got a F-150 with around 225K miles that just keeps on trucking. If I had to replace it, it would be another F-150 gasser.
   / Old Diesel-Heads Going Gas #4
I have a 1993 Ford F250 7.3L non turbo and I will keep it until it dies. It has 240,000 mile on the clock and runs good. That said I would not buy any of the new diesels because of the cost and the fact that I cannot afford to fix one when it has a problem. My next truck will be a used Diesel or a gasser. I have run the #s and it is not worth it in my book. Now if I towed all of the time ad I needed the torque and it was a paying proposition but...... its not. I sure like the older simple diesels.
   / Old Diesel-Heads Going Gas #5
Only real option, and its days are numbered, is the Ford V-10. The other manufactures do not have a good powered low torque producing V8 and Ford is doing a stupid thing and following suit with the high revving V8. Not good for a large truck but would be fun in a 1/2 ton that is not used for real truck duty or a car.:D
Chris
   / Old Diesel-Heads Going Gas #6
The EPA has, IMO, gone TOO FAR and more importantly too fast.
I would not consider a "new" diesel. By the time you factor in the added purchase, operating and maintenance costs, you lose over a gas engine. Yes, resale value IS higher, but you don't get back 100% of the added up-front cost, so you lose there. You pay more interest (money you *could* be spending on other things) to finance the more expensive diesel. You need more oil, more expensive filters, DEF and to clean the DPF periodically. None of that applies to a gasser.
The 5.4L 3V makes WAY more WHP and WTq than the 460/454s of by-gone days, and they are good enough for me in terms of efficiency.
Now, a Gen 1 or 2 Dodge CTD would be the best of both worlds, but not available "new" or anything even close to it.
   / Old Diesel-Heads Going Gas #7
Chris
I agree--the Ford V-10 is pretty torquey right out of the box.
The old Dodge 8.0L V10 gasser needs after market upgrades to goose up torque below 2000 rpm. Gear Vendors has this Overdrive-Underdrive add-on unit for the tranny that they say gives something like 420 lb-ft at 1500 rpm. Fairly spensive upgrade--$2300 to $5000 depending on model.
   / Old Diesel-Heads Going Gas #8
Next truck will be a new Duramax. It will easily pay fror itself, since Diesel is still cheaper than gas up here.
df.
   / Old Diesel-Heads Going Gas #9
df.
Where do you live? Diesel is $.25 or more per gallon here in Indiana. Trust me, I have 3 diesels that are thirsty.
Chris
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
1 pallet of Truck equipment (A53117)
1 pallet of Truck...
