Oil & Fuel Old diesel fuel
   / Old diesel fuel #1
fuseboxer
Gaines, Michigan
two john deere Sabres (2554-Scotts) and 4410 john deere ,Allis Chalmers WD , 5' Cub Cadet Zero turn
We had a very mild winter and little snow last year in Michigan and only used my JD4410 once and that was probably not necessary. Snow melted in the next few days. My question is that I have old fuel that is at least 12 months old in my tractor. I use the usual fuel additives that many use and recommend. Looks like I have only had about 6 hours of use in over a year. Should I change the fuel? Just drain the water skimmer? Starts and runs good. What would you do? ---Fuseboxer :confused3:
   / Old diesel fuel #2
me? I'd drain water out and see if she ran. if so.. treat again and add some fresh and go.
if she don't like it.
change filter. drain fuel and save.. and refill with good fuel.. bleed, and use the old fuel as top off after straining it for solids.
check tank and tap for biologicals..
   / Old diesel fuel #3
I'd just go ahead using it.
   / Old diesel fuel #4
For once I agree with LBrown, just go ahead and use it. Keep an eye on the water separator but if it looks good go for it.
   / Old diesel fuel #5
Only thing that affects diesel are contaminants such as dirt or water. Water contributes to algae growth. I agree just check water separator and use the fuel.
   / Old diesel fuel #6
That's all you need to do with diesel.
   / Old diesel fuel #7
Just order some PRI-G (gas) and PRI-D (diesel) fuel stabilizers that will keep fuel/gas fresh for 10+ years. I researched and found it and purchased on Amazon.
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
F/500 Seed Spreader (A50325)
F/500 Seed...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2025 Chery 10ft 15 Drawer 2 Cabinet Workbench (A50325)
2025 Chery 10ft 15...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
