Old Air Compressor
/ Old Air Compressor #1
Barneyhunts
Dimock, Pa.
Kubota L4240 Kubota B7800, Kubota BX2200
I recently came into possession of an old Montgomery Ward air compressor. It turns over easily by hand, but does not have any inlet air filters. They should sit right on top of each cylinder. I'd like to know what type of material would be required to make new ones? They would be flat and approximately 1/2" thick.
Thanks,
Barney
/ Old Air Compressor #2
Campbell Hausfeld makes a rectangular felt type filter like you describe. You can get it at Tractor Supply. You may need 2 filters to be long enough depending on the size of your air inlet.
/ Old Air Compressor #3
if you go by the local vacuum cleaner store they might have filter material that breathes well but keeps out dust that is where i got my last ones, they just cut it out of the 2x2 sheet of fliter material they had, they use it for all brands and its cheaper than the stock/OEM ones, if figured it it works for a vacuum motor it would work for my air compressor
/ Old Air Compressor #4
That gets me wondering. I have never even thought about filters on my compressors! Condensate in the tanks, but not filters.
/ Old Air Compressor #6
I have an old Sears like that. Cut 1/2 inch off a rectangle carwash sponge I had, fit perfect.
/ Old Air Compressor #7
We clean ours once a month. They are a scrubber pad type like a precleaner for some other applications. Also use an automatic drain valve so the tanks dont build up too much water.
/ Old Air Compressor #8
Montgomery Ward went under 20 years ago, so that is pretty old for an air compressor. I thought the tanks had an expiration date. Cast iron ones will last longer. And oiled compressors last longer.
/ Old Air Compressor #9
The compressor itself should be fine, I'm not aware of any expiration date for them. The tanks however, are only "good" for 10 years and either need to be replaced or inspected at that point.
/ Old Air Compressor #10
I've never heard of an air comp. tank expiration date. I used to have a 60 gallon air compressor I bought from Northern Tool (Formerly Northern Hydraulic). It was about 30 years old when the bottom of the tank finally rusted out from years of condensate. It wasn't used daily but only a few times each week. Condensate was blown out weekly (never a lot came out) and compressor oil and air filter was changed annually. The tank bottom was paper thin by then and didn't want to chance welding on a patch.
I replaced mine with a new 80 gallon compressor and gave the old one to a friend who had a 3 year old tank with a bad compressor. He put my old compressor on his tank and it is still in use today. It is well over 40 years old now.
I'm sure the OP will be able to find or adapt a new air filter.
Thank you all for your input. I found another forum dedicated to Montgomery Ward air compressors and on it found a part number for an inlet filter and a silencer. Used to part numbers and actually found a current supplier. Thank you again for taking the time to comment. Regards, Barney
2018 Ram 1500 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 Crew...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
