Old 3PH question.
   / Old 3PH question. #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
I'm know this is an old question, but I can't find it in the archives. Does the 1/4 inching valve on the B7610 and B7800 have an adjustment for the "up'" speed? /forums/images/graemlins/confused.gif The 3PH seems to shoot up real fast if you bypass the 1/4 inch feature. Also, has anyone found extendable lower links/stabilizers that will fit these machines?
Ronster
   / Old 3PH question. #2
I don't beleive the speed up is adjustable.
Here is a thread on the lower links that fit a B2910. Click Here They will fit the B7800 with no problems.
You can also use Pat's Easy Change for the ends. They do add some length to the arms though.
   / Old 3PH question.
ronjhall,thanks for the info. I was looking at the parts list for a B7610/ and wondwered if you could swap the 3PH control vavle on a B7610 or B7800 with another vavle from a different Kubota? If so, I'll bet they're not cheap$$$.
Ronster
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
