Okay here's a really dumb question
   / Okay here's a really dumb question #1
NIXON
West Sunbury ,Pa.
L3130 hst
Okay here\'s a really dumb question
Does anyone make a mid mounted mower that is heavy duty ? AS in "brush hog " ? I've got a bunch of trees on the property ,and getting through them would be a problem with a rear mounted brush hog . A mid mount finish mower just wouldn't last . John
   / Okay here's a really dumb question #2
Re: Okay here\'s a really dumb question
</font><font color="blue" class="small">( I've got a bunch of trees on the property ,and getting through them would be a problem with a rear mounted brush hog . John)</font>
I've certainly never heard of a mid mount rotary cutter. Why is a rear mount such a problem? Is it because the rear mount will swing out on turns and you don't have room between the large trees? What are you trying to cut? Saplings, brush?
   / Okay here's a really dumb question #3
Danny,
That is a pretty good question. I was wondering why he couldn't get a bush hog in there if he could get a MMM in there. But I didn't think of the turning thing and it may be a problem for him.
I will want to watch this post to see how it comes out.
Murph
Danny, You hit it on the head! Most of my property is Larch and Fir trees . Very closely planted . 6 ft or less . I'm sure I could get to most of it with a 3pt brush hog,but it would be a real pain . Most of what I want to cut is blackberry and blue berry bush . ,along with some multi florra rose . However there are some small stumps (Xmas tree cutting ) and rocks that I'd like to avoid . The swinging of a back mounted cutter would make for a lot of work avoiding obsticles . Just lazy, I suppose . Like I said , it is a dumb ??? /forums/images/graemlins/smile.gifJohn
   / Okay here's a really dumb question #5
There was a thread on these a while ago and folks seemed to really like them: Rugged Cut Walk-Behind Mower
   / Okay here's a really dumb question #6
I used a walk behind blade before I purchased my tractor. It was manufactured by Bachtold and that thing worked like magic. I "mowed" right through strand after strand of 1-3 inch alder trees like they were grass. It was very similar to the DR. Mower you see but this thing was a little more suited for commercial use. It can go anywhere. You might want to check this out. I've personally never heard of or seen a mid-mount-hog. Maybe because they fear that too many things might get stuck underneath the tractor. When I brush hog sometimes saplings I mow over bend over spring back and need another going over. Just a guess /forums/images/graemlins/confused.gif
   / Okay here's a really dumb question #7
<font color="blue">"...and getting through them would be a problem with a rear mounted brush hog..."</font>
Anticipate the turning radius you have and plan accordingly. In tight corners on the property's perimeter think of backing in to cut down brush, saplings, etc.
....Bob
   / Okay here's a really dumb question #8
Good point Rancar. I do alot of backing into brush when using the hog.
   / Okay here's a really dumb question #9
I have a John Deere 6 foot MMM - That sucker is very very heavy - JD promotes their 5 foot mower as a 7 Iron and the 6 foot is even a thicker deck. A problem with a MMM would be you can't raise it very high.
7 Iron
   / Okay here's a really dumb question #10
I actually prefer backing in on heavy stuff. Cut a little, then move forward and look for those hidden tree stumps (which I have a lot of). Saves wear on the front and bottom of tractor. Probably a little overcautious but I don't have a lot of heavy hogging as a rule.
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
Truck Wheel Fenders (A51692)
Truck Wheel...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
2017 Ford F-450 XL (A50123)
2017 Ford F-450 XL...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
