OK wheres rick ?
   / OK wheres rick ? #1
D7E
Veteran Member
manitoba
Versatile 895 Versatile 876 Ford TW20 Ford TW5 MF 3505 FWA MF 390 FWA Ford 7600 Fiat 766 FWA JD 2030 MF 165 MF 35 Fordson major x 3 CAT 416 b Backhoe Case 580 b backhoe MF
Ford 7600 , Has no PTO when the dual power is in "High" ?
   / OK wheres rick ? #2
Sorry, I'm not Rick but I've done a few of these. :)
Sounds like a blown seal or cracked piston in the dual power assembly. An internal leak in the dual power will drop the hydraulic pressure enough where the PTO clutch cannot lock up. Be careful running the tractor like this because either the dual power or the PTO clutch slipping will burn the clutch plates in each assembly in a matter of minutes.
   / OK wheres rick ? #3
Agreed. The problem is most likely to be in the direct drive circuit of the DP. It will be cheaper to fix it before more collateral damage occurs.
12in Backhoe Bucket (A50397)
12in Backhoe...
2014 Big Tex 12ft. S/A Utility Trailer (A48082)
2014 Big Tex 12ft...
2019 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A50458)
2019 CATERPILLAR...
KSI Conveyor (A50397)
2013 JCB 4CX ECO BACKHOE (A50458)
2013 JCB 4CX ECO...
LEE G550 MOTORGRADER (A50458)
LEE G550...
