OK wheres rick ?
/ OK wheres rick ? #1
D7E
manitoba
Versatile 895 Versatile 876 Ford TW20 Ford TW5 MF 3505 FWA MF 390 FWA Ford 7600 Fiat 766 FWA JD 2030 MF 165 MF 35 Fordson major x 3 CAT 416 b Backhoe Case 580 b backhoe MF
Ford 7600 , Has no PTO when the dual power is in "High" ?
/ OK wheres rick ? #2
Sorry, I'm not Rick but I've done a few of these. :)
Sounds like a blown seal or cracked piston in the dual power assembly. An internal leak in the dual power will drop the hydraulic pressure enough where the PTO clutch cannot lock up. Be careful running the tractor like this because either the dual power or the PTO clutch slipping will burn the clutch plates in each assembly in a matter of minutes.
/ OK wheres rick ? #3
Agreed. The problem is most likely to be in the direct drive circuit of the DP. It will be cheaper to fix it before more collateral damage occurs.
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
Location Info Please
Four Bridgestone Semi Tires (A62177)
Four Bridgestone...
New/Unused Landhonor Leaf Blower (A61166)
New/Unused...
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
Here are some similar links:
  • Article
  • Type: Trucks & Vehicles
Replies
0
Views
45
  • Article
Replies
0
Views
74
  • Article
Replies
0
Views
68
