OK what trans/hydro oil are you using?
   / OK what trans/hydro oil are you using? #1
Neat 1500
Platinum Member
Queensland,Australia
Only a YM14 MkII
I am about to buy some oil to replace the trans/hydraulic fluid in my 1500 Yanmar.i was going to use a "J" spec ATF as i have some of this and i use it in my vehicles,but i am still not convinced.should i use UTF or Hy-Gard or ???? i want to buy the right oil as the one that was in it wasnt right but i need a push one way or the other.
i bought 20L of AgriTrans, a Caltex(Texaco) Hydro/Trans fluid that meets the requirements.It has made a difference to it already,smoother and easier gear changes and quieter hydro pump and rams.
   / OK what trans/hydro oil are you using? #3
If it seems like it's working, you should be ok. I tried a off-brand ($25 for 5 gals))in my tractor and the tractor shifted fine but I would get brake chatter on steep hills. I went back to HY-guard($55 for 5 gals) and it went away.:cool:
   / OK what trans/hydro oil are you using? #4
I went with Amsoil and it was quieter and smoother. I don't know if you can get Amsoil down under.
   / OK what trans/hydro oil are you using? #6
I have a greymarket Yanmar and use the same fluid that is recommended for John Deere tractors since Yanmar made the motors for John Deere I thought that would be a good oil. So far it is working good. Cant remember the number maybe 202, but Atwoods only had two types and one was for JD. I had both types and visually I couldnt tell any difference.
MACK T/A DUMP TRUCK (A60430)
MACK T/A DUMP...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
Kubota L4701 (A53317)
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
