OK to weld on portable generator frame?
   / OK to weld on portable generator frame? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a 20 year old Generac 10K portable generator that's in mint condition and I would like to weld two brackets on the frame for extra wheels. Not sure if this is OK because of possible damage to electricals or generator or whatever. Anyone know if I can weld on my generator frame --MIG--and not damage something on the generator?
   / OK to weld on portable generator frame? #2
A 20yo gen probably doesn’t have a control board and if it does I’m betting it’s one plug (that I would undo). Make sure the ground is good. MIG is lower risk than High Freq TIG.
   / OK to weld on portable generator frame? #3
I think the warranty is over by now, weld away.. the closer you have the ground clamp to the weld area, the less current you will induce in the frame. you don't need to have it within a few inches if you can't though..
   / OK to weld on portable generator frame? #4
Why not just fasten on some casters with u-bolts and be free of the horror.
I'm starting to lean this way. A problem is the wheels have to line up with the back wheels and the whole thing needs to withstand the running and vibration of almost 300 lbs.
   / OK to weld on portable generator frame? #6
I see no issue. Just to make sure, have a good solid ground connection close to the work on the same piece of metal.
   / OK to weld on portable generator frame? #7
Well
That’s not as bad as a friend who asked me about welding on his generator frame but running the welder off of the same generator in the process.
   / OK to weld on portable generator frame? #8
Well
Well that's the question that was in my mind.
   / OK to weld on portable generator frame? #9
IF it has a battery for an electric start.. UNHOOK the battery.. & go to town on it.
   / OK to weld on portable generator frame? #10
as an MSEE, I can't think of why just unhooking the battery would serve a useful purpose, removing the battery, and placing it far away would prevent the risk of an explosion from hydrogen gas from the battery, that's about it..
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
2006 S&H HORSE TRAILER (A52472)
2006 S&H HORSE...
