OK to mix AW-32 and "general" tractor hyd fluid?
   / OK to mix AW-32 and "general" tractor hyd fluid? #1
joerocker
SE Alabama
Farm Pro 2420
Title says it all...can I mix the two? I don't want to but a 5 gallon drum of AW-32 if I can get by with a 2 gallon container of general purpose hyd fluid. It's just to lift my 3pt, not FEL or anything else. VERY light duty...
   / OK to mix AW-32 and "general" tractor hyd fluid? #2
Depends on the tractor but I would say no! On my tractor if I run anything other than AW32 or AW46 I get a foaming problem. That makes a mess out the vent and does damage to the hydraulics themselves.
Chris
   / OK to mix AW-32 and "general" tractor hyd fluid? #3
Just took a look at your profile and I saw you own a Chinese tractor. Do not use anything other than hydro fluid if this is the machine your are talking about. AW32 is the way to go unless you want big problems.
Chris
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
UNUSED LANDHONOR LHR-CIA200 - 200# CAST IRON ANVIL (A54757)
UNUSED LANDHONOR...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
