OK to mix AW-32 and "general" tractor hyd fluid?
   / OK to mix AW-32 and "general" tractor hyd fluid? #1
joerocker
SE Alabama
Farm Pro 2420
Title says it all...can I mix the two? I don't want to but a 5 gallon drum of AW-32 if I can get by with a 2 gallon container of general purpose hyd fluid. It's just to lift my 3pt, not FEL or anything else. VERY light duty...
   / OK to mix AW-32 and "general" tractor hyd fluid? #2
Depends on the tractor but I would say no! On my tractor if I run anything other than AW32 or AW46 I get a foaming problem. That makes a mess out the vent and does damage to the hydraulics themselves.
Chris
   / OK to mix AW-32 and "general" tractor hyd fluid? #3
Just took a look at your profile and I saw you own a Chinese tractor. Do not use anything other than hydro fluid if this is the machine your are talking about. AW32 is the way to go unless you want big problems.
Chris
Makinex PHT-140 Electric Powered Hand Truck (A52377)
Makinex PHT-140...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
