OK so I boke my door glass...
   / OK so I boke my door glass... #1
Catskin
Tawas, MI
LS XR3135H
on the right side. I have a 2017 vintage LS xr3135H cab model which I'm told is equivalent to a New Holland Boomer 40 cab, and I'm having a heck of a time finding new door glass online.
anybody know the part numbers and where to buy?
   / OK so I boke my door glass... #2
No, but I do know the glass will lighten your wallet appreciably. Shattered the door glass on one of my M9 cab tractors and the glass alone (no hardware) was just shy of $1000 bucks.
   / OK so I boke my door glass... #3
Messicks has them. I broke my glass door and needed a new handle too - they have them in stock. Get the number for the door on the ls parts site and add an "MT" to the part number search on Messicks web site.
Here's a link for the RH door that I found please verify that is what your part is on LS parts site and or call messicks to confirm its in the $500 range and in stock - I bought 1 from them was fast and easy - call to be sure its all inclusive an includes the seal.
   / OK so I boke my door glass... #4
This is a good video of a LS owner that broke his left door and replaced it. He found that getting it from New Holland was cheaper and easier. He also talks about the procedure to replace it.
   / OK so I boke my door glass... #5
When I replaced the door glass on my M9 cab, I didn't need or require and YT instructions or anything else for that matter, pretty much plug and play and I suspect mine was appreciably more expensive because my tractor cab is appreciably larger than the OP's in the first place.
I will say that after shattering the door glass, I'm real careful about making sure the doors are closed when moving the tractor.
Only takes a slight, slight bending force to cause the glass to explosively shatter.
   / OK so I boke my door glass... #6
My entire kioti windshield only cost $505.00 plus $65 for new rubber gasket. A thick plexygless replacement quote was nearly $1000
   / OK so I boke my door glass... #7
It's plexiglass btw... Never broke a windshield and my windshield is actually 3 parts. The upper and 2 lowers but then I have front fenders on my cab tractor which minimizes the chance of thrown rocks and keeps the crud at bay as well.
I'd never use plexiglass in place of a tempered glass windshield or door panels because eventually it will become hard to see through.
   / OK so I boke my door glass... #8
This - rule #1 = always shut the doors before moving the tractor. I broke mine when I was doing log work - lifting logs to cut them down. How could I possibly fvck that up right?? Wrong. I was in and out of the cab to lift then cut, move the chain and repeat so was a pain to keep shutting the doors... opps. I moved my tractor like 2 feet an bam whata mess.
2022 BOBCAT T76 PLATINUM R SERIES SKID STEER (A51246)
2022 BOBCAT T76...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
Case SV185 Compact Wheel Loader Skid Steer (A51691)
Case SV185 Compact...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
