OK, need advice on a sub-cut for mowing
   / OK, need advice on a sub-cut for mowing #1
tomd999
Platinum Member
Viva Manchvegas!
'10 3320 cab
OK, need advice on a CUT for mowing
Hi All,
OK, here is my situation.
1) I live on a mountain, my lawn changes 300+ feet in elevation from bottom to top.
2) Because of #1, I have killed the hydrostats on a Cub Cadet Tank and a Wright Stander zero turn mowers
3) Currently I'm using a Deere 318 that has no issues with the hills with the overbuilt hydrostat it has but I'm concerned about the Onan on the hills as they have a very shallow sump. ( I don't want to spend the $ to repower it with a Honda as the kit cost is about 100% of the resale value of the tractor and I would never recover my investment)
4) I could use my 3320 cab to mow but I would prefer not to as it's around 6K Lbs and I have a septic system.
So, after all that, my thinking is to look for a small Diesel CUT with a gear trans and a mid mount mower. Off the top of my head something like the Deere 655, 755, 790 series, Ford 1210, 1215, Kubota B 6100, 7100 series and along those lines. Don't want to get into Chinese stuff.
What are your thoughts on the various used gear trans CUTs out there keeping in mind that I'm trying to cap the cost at under 5K for the older models and maybe up to 7 to 8K for the 790/3005 Deere's
Tom
   / OK, need advice on a sub-cut for mowing #2
None of the ones you listed are Sub Compact tractors.
Listed ones are all Compact Utility Tractors(CUTS)
A Subcut is what I have in my avatar........Massey GC2400. others are Kubota's BX series JD 1025r and such and they are hydrostatic.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
2001 Ford F150 (A50121)
2001 Ford F150...
