sawtooth
Veteran Member
- Joined
- Sep 19, 2007
- Messages
- 1,192
- Location
- Eden NC
- Tractor
- Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Well I'm in the market for a new tractor and have always had the older iron with torque motors low rpm tractors. I've even driven newer masseys 563 model and they just pull like crazy. Now i like the Kubota cause they are cheaper and have good reliability. But from the tractors i've drove i hate the high RPM's. Whats the deal with this? I mean really 2500RPM to bush hog. Also, if i'm disking and plowing now i can start off in a nice tall gear at idle and the tractor just takes off. I'm assuming you must rev these new diesels to get them going correct? Even the rear end on these new tractors look like toys compared to the old iron. I'm just a little confused cause i've heard several people mention i will not be happy with these new light weight high revving engines. From no pulling power, clutches that won't last, etc. Mostly what i need is 45-50pto power, use a 6ft bush hog, and pull at heavy (1100lb 8ft disk). My 3930's and 4000SU (2wheel drive) fords work these type equipment with ease. Any opionions would be greatly appreciated.
