OK - Goping nuts with 3PH Attaching/Detaching - Please help!!!
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #1
rixtory
Bronze Member
Bethlehem, PA
Kubota BX2200
Hi All,
Have a BX2200 Class 0/1 3PH. I have a weight box (full of rocks) that I put on and take off when using the loader. Problem is, It is a bear to get the 3PH lower arms on the weight box pins. I loosen the arms up and but can never get them lined up and on the pins. The weight box is simply to heavy for me to try to shift or shimmy to get the arms on.
The only way I can then get the arms to slide onto the pins is to draw them in is by using a wrench and tightening the adjusting links.
I have no problems putting my rear blade on, as I can easily drag/shift the blade a bit to get the pins lined up with the arms, and slide the arms on.
I spent many young years on a farm and never recalled this issue. Am I doing something wrong here? is there an easier way to get the arms on the pins of heavy, immobile objects?
Rick
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #2
2 simple solutions.
1. the next time you want to take box off, set it on a dolly, pipes, or on a greased up small block of wood in the center. Any of these should let you pivot the box easily.
2. get a Freedom Hitch. I am pretty sure thats the name brand I use( I'll double check tonight) or simular type of hitch that uses interlocking triangles.
We have them on about half the implements, they are wonderfull. Just back up get the tractor triangle anywhere in the implement triangle and lift. When unhooking just pull the lever, from the tractor seat, lower and drive off.
These are more expensive than the other styles of hitches but IMHO they are worth it. We drop implements anywhere uneven dirt, in the woods, on a slope and come back next time with any of the 3 tractors and hook right up.
http://www.agrabilityproject.org/newsletter/winter_2002/3.cfm
is a link to a page that shows some hitches
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #3
I agree - some type of quick-hitch is the ticket. I have a JD and use the I-Match but there are others out there as well.
Dropping the ballast and putting it back on is, literally, about a 15 second effort. Back-up, align, pick-up ballast box, flip two levers, drive away. All from the seat I might add.
Scott
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #4
Some good ideas by others already listed.
You may also want to keep a pry bar or 2X4 nearby - they can be good persueders also
When hooking up my winch, I sometimes get one side hooked up and then move the tractor to align the other side enough to get the 2nd pin in, hooking upthe top link and pto last
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #5
If you have adjustable sway chains it can help to loosen them before hooking up.
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #6
Are the lower link ball joints nice a free? Mine were almost stuck solid which made the alignment have to be dead on ... till I fixed them with an 8# hammer.
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #7
I would go for a dolly. They make these dollys for cars that each hold one wheel at 1500 lbs. The dolley has swiveling wheels at all four corners. JCWhitney, summit, or another car parts catalog source should hae them at low cost.
If you are not on a hard floor surface though then it will be tougher. A quick-hitch system may be the only wayt to go.
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #8
I have the same problem with my bush hog. Big heavy monster.
I never can seem to back up to an implement just right.
Most of my stuff I can shift one way or the other by hand.
But not the bush hog. I can't budge it by hand.
But, I found out if I keep a 6 foot T post nearby I can use it as a pry bar.
I can shift the bush hog anywhere I need it to go now. Easy to hook up.
Here's another tip I learned. I have solid sway bars.
Put the drag links on and the top link on and lift the implement off the ground.
Then put the sway bars on and the lynch pins in.
Makes it a whole lot easier to get the sway bars on.
Pooh Bear
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #9
If you park the weight box on concrete when not in use go the Harbor Freight and get yourself some stout castor's that can be permanently fixed to the bottom of the weight box. Hook-up will be a snap after that.
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #10
Pat's easy change system might be the ticket for you. I have one and it has solved all my hook-up problems.... be aware that top link length may need to be adjused if you get one... Here's his site.
http://www.greenwellmfg.com/
He advertises on TBN. Good guy.
Thansk everyone- I ended up seeing the harbor freight thread and ordered a chinese knockoff quick change hitch for $69.99 plus $5.00 off and $8.99 shiping. I hope it works!!!!
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #12
Use to have the same issues, I am 61, 6 foot tall and only weigh 145 pounds, kinda hard for me to move anything that weighs over 50 pounds. Read a tip on here about dropping the FEL and using it to nudge the tractor back and forth when hooking up and man does that work.
I back up to the implement just kinda make sure it's centered, curl the front of the bucket so the blade is straight down and drop it to the point it just takes the weight off the front wheels. Also have a hydraulic top link which makes it easy to hook up the top link. Hydraulics is your friend :)
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #13
All my implements are on dollies and stay on smooth concrete garage floor. My Gannon Box Blade is what I use as FEL counterweight. Things go on and off 3ph in approx. 3 minutes. I use a small sledge hammer to tap the lower arms on and off. Homebrew's correct about the balls. They get looser with time and lube.
/ OK - Goping nuts with 3PH Attaching/Detaching - Please help!!! #14
Had the same problem. Bought a Pat's Easy Change!!!! awesome product. And it fits all my implements!!! Hopefully you nockoff works as well!!!
Cheers!!
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
CASE CX160C EXCAVATOR (A65053)
CASE CX160C...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
