Oil weight for EX3200
   / Oil weight for EX3200 #1
yanmar3200
Cub Yanmar 3200
Getting ready to do my 50hr maintenance on my Ex3200. Just wondering what the best weight oil to use. I live in northeast Mn. and we don't have many days above 90 and when we do, I doubt Ill be useing the tractor.I use the tractor alot in the winter for plowing snow and it always starts with whatever weight oil it came from the factory with. Does anyone know what weight oil is shipped in these engines? Thinking about Shell rotella 10-30 but if these tractors come shipped with 15-40 that may also work. Just curious what the majority are useing in their unit. Thanks
   / Oil weight for EX3200 #2
I live in NE Ohio but only use the tractor in the summer for mowing. I use the same oil I use in my cars, for convenience - 5W30 - and have had no problems in a 1450 or a 3235.
Bob B.
   / Oil weight for EX3200 #3
I use 5-40 mobil 1 synthetic diesel oil in my chevy duramax.I suppose I could use it in my tractor as well. Good idea :thumbsup:Thanks!
   / Oil weight for EX3200 #5
Hey I f your tractor is new and under warranty use what your manual says. That way if the un-thinkable happens your covered, just my take.
DevilDog
   / Oil weight for EX3200 #6
The 10w-30 listed is based on average temperature ranges. One can use a lower viscosity when temps drop and a higher one when hotter. The 5w-40 covers all of that and is synthetic based, not the natural based stuff from the factory. It's the "C" rating that is the important specification, not the viscosity.
If anything "unthinkable" happens, an oil analysis will more than likely dispell any wrong doing from the oil, which for the most part, is hardly ever the cause, unless you put in straight 90 weight!
@Bob Bainbridge: please make sure the oil that you are using for your car has the "C" ( for diesels) rating as well as the "S" (for gas) located on the back lable of the bottle. If it does not contain a "C" rating, you must not use it in a diesel engine. Long term use will cause damage!
   / Oil weight for EX3200 #7
I'm in NE Ohio just changed mine the dealer said they use 15w-40 here but want 7.00/qt picked up Shell rotella 15w40 15.00/gal at auto parts store be sure to check the rating I think it required CF, you'll need a little over a gal.
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2008 AAR MOBILITY SYSTEM REFRIGERATED BOX (A52576)
2008 AAR MOBILITY...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
LMC G500-500A LOT NUMBER 232 (A53084)
LMC G500-500A LOT...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
10 in Small Excavator Bucket (A52377)
10 in Small...
