Oil type
   / Oil type #1
Jonathan Gazarian
Farm Pro ??
What type of oil do I use for my Farm Pro 25HP Diesel 2WD tractor?
   / Oil type #2
You definitely want an oil formulated for a diesel engine. Rotella is favored by many here.
Steve
   / Oil type #3
I use Mobil 1 0w30. It's lightly diesel rated. I change it once/yr and generally only put 70-100 hours on it.
There are two diesel oils at 5w30 that are rated for long drains (e.g. 10k miles in cars and trucks). These are Castrol SLX and Mobil 1 ESP. Both are 5w30.
Almost all other diesel rated oils are 5w40 to 15w40. I would not use 15w40 because the oil won't get to the valve train for a few seconds at startup; whereas, a 5wxx or 0wxx will get there almost instantaneously, particularly the 0wxx.
Ralph
   / Oil type #4
there are probably more diesel's running 15w40 than anything else.. and spec'd by the manufacturer to do so.
guess all their engineers are FOS right? :(
soundguy
   / Oil type #6
i've seen a book on the 2425 that said 15w40 crankcase, and sae 30 injector pump, and aw32 hydro.. etc.. 80/9- trans/rear
soundguy
   / Oil type #7
soundguy
sure since most diesel (trucks; rigs hauling food etc) are running 24/7 too
! Maybe in FL a 15w-40 will work but up north it is not the top pick....It will work with allkinds of external heating...Aka, there are better oil weights to use.
I do not but my faith in engineers since they do NOT make the product. It is the marketing and business end (aka bean couters)..
   / Oil type #8
Times are changing with todays quality HDEO's a 15w40 is no longer the ONLY choice out there many times a manufacture I've seen depending on climate will spec anything from a 15w40 to a 10w30,30w,10w!! go by what the engine manufacture recommends is a good place to start.
just make sure it carys the currant CJ4 or CI4 HDEO spec and you cant go wrong your protected well.
   / Oil type #9
alrighty.. 15w40 is junk except in florida.
I think i'll bow out of this one now.
soundguy
   / Oil type #10
soundguy
WEll you know, you are in wonderful FL..little cuba!!!!!!
Man, you sound like the old cowboydoc here..
1838 (A51248)
1838 (A51248)
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
2024 KMC 7406 (A53084)
2239 (A51244)
2239 (A51244)
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
