Oil & Fuel Oil type for YM 4220
   / Oil type for YM 4220 #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I posted this on Oils and lubricants but am getting no response so I am going to copy it here also. Anyone that can confirm type/ grade of oil manufacturer recommends also appreciated. Dealer said he used AW 32 but I am now having trouble as described below and am not sure this is the right oil.
As posted on Oils and Lubricants:
I have a Yanmar 4220D and bought all the operations manuals with it, but all the parts etc are in Japanese. Can anyone tell me the type of hydraulic oil it takes. Local parts houses either have AW 32 or JD303 equivalent. I have replaced it with AW 32 but have got to thinking that since Yanmar made some tractors for John Deere, maybe the JD hydraulic oil would more nearly match.
The filter screen stopped up on it with green slime and black jelly looking material and it took 3 oil changes to get it all flushed out, but now the hydraulics are jerky and slow and it takes a few minutes of circulation before it will lift the FEL. I have been advised by one of the Net members that the pump may be bad now. It was working good till the screen fouled,and I may have damaged it by letting it run with the screen stopped up. IT took me a while to find the screen to clean it. While the screen was stopped up, nothing worked and it would not move as the hydraulic clutch would also not engage.
ANY ADVICE on this. IF new Pump is needed, Where can I find a NEW one.
   / Oil type for YM 4220 #3
AW32 appears to be a hydraulic oil. It doesn't sound like it would meet the requirements of your tractor. JD303 is a hydraulic/transmission fluid. It is designed for hydraulics, wet clutches & brakes, gears & bearings. Your tractors has all of these except wet brakes. I can supply you with a new pump.
   / Oil type for YM 4220 #4
Check the post I left for you in the Lubricants forum where you posted the same question.
FOUR WAY BLADE SKID STEER ATTACHMENT (A58216)
FOUR WAY BLADE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2025 Anvil 16 ft S/A Enclosed Trailer (A56859)
2025 Anvil 16 ft...
2007 Ford F-450 Chip Dump Truck, VIN # 1FDXF47P97EB35140 (A57453)
2007 Ford F-450...
JMR 40" Mini Grapple (A57149)
JMR 40" Mini...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
