Oil Suggestions for chain box of Master-Till RotoTiller.
   / Oil Suggestions for chain box of Master-Till RotoTiller. #1
kg7il
Eatonville, Washington
Kubota L3800
I need some suggestions based on your experiences.
What OIL or Lubrication would you put in the chainbox of this old rototiller.
We were just happy to get it running, I'm sure most anything will work fine, but thought someone that knows something might be a good approach.
I just got by BIL's old Master-Till running. I put the electronic ignition on it. Briggs and Stratton is all clear to me. RotoTiller is not.
I picked up some 85w-140 and will toss some of that in with a bit of 30w....
Lotsa views on this question, but no help to be found....
I'll let you know how this works. I don't want to crack the chaincase plan on filling it to the overflow and let'er rip.
   / Oil Suggestions for chain box of Master-Till RotoTiller. #3
If it ends up having leaks you can fill it with JD cornhead grease. Its semifluid and wont leak.
   / Oil Suggestions for chain box of Master-Till RotoTiller. #4
kg7il,
I was going to suggest 80w90, but I think you did good. Like last post said, IF it doesn't leak, you got it made. GO FOR IT ! ! !
Dave
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
