Oil Sender Leak
   / Oil Sender Leak #1
dmccue
Bronze Member
Melbourne, Florida
Kioti CK20, Yanmar YM2000, and Sears Garden Tractor 19.5HP
I have a Yanmar YM2000 tractor. After engine warmup I notice an oil leak which appears to be coming from around the oil sender switch.
Is the remedy to replace this switch? If so, is there a special procedure to do this? Is a replacement switch available?
   / Oil Sender Leak #2
It is more than likely leaking where the 2 parts of the switch are put together. I took mine to NAPA and they matched it to another one. They said there was only 2 kinds, One for a light and one for a gauge. It stopped my leak.
Eugene
   / Oil Sender Leak #3
Carquest part #PS138 is a match for your leaking sensor
   / Oil Sender Leak #4
My 1700 had a leak on the sender, I thought it wasn't tight.. tightened it.. cracked it.. got anohter one.. thread taped it for piece of mind, and didn't worry about it after that.
Soundguy
   / Oil Sender Leak #5
A bit of advice on installing an oil pressure sender. Using thread tape is not generally advisable. If a piece were to get loose in the oil system, it could easily plug a small oil passage and starve a bearing. Try using some thread sealer like plumbers use - I think I got some locktite. The mechanics here at Mack Trucks use it exclusively for these types of applications.
   / Oil Sender Leak #6
Actually that is what i did, I used the liquid tape sealer. I never use the real tape anymore, I'm spoiled on the liquid sealer.. it works great. The grey stuff for gasline is pretty decent as well.
I probably should have specified liquid tape.. i just get into the habit of saying 'taping it'. etc.
thanks for the reminder!
Soundguy
(1) 225 Gallons of Bleach (A51573)
(1) 225 Gallons of...
2015 HINO XJC740 BOX TRUCK (A52576)
2015 HINO XJC740...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2019 JOHN DEERE 8295R LOT NUMBER 181 (A53084)
2019 JOHN DEERE...
