Oil Question
   / Oil Question #1
N1ST
Enfield, CT
Kubota B7800
The mfg of a mower I have recommends sae 30w engine oil. Because of this it recommends not starting it unless it's 40f or warmer. Can 30w be replaced with something like 5w-30 and still offer the same protection? I think 5w-30 would allow me to run the engine in the winter if I need to move the mower.
   / Oil Question #2
Yes, that should be fine. I would probably use 10W-30 if winter use will be only an occasional possibility, and 5W-30 if regular winter use is your plan.
   / Oil Question #3
Why would you want to start it?
Bob
   / Oil Question #4
You should be fine with a multi-visosity like 5W or 10W/30. Many manufacturers of small engines are starting to spec multi-viscosity oils in their engines these day's. They just seem to be a few decades behind the auto industry.
   / Oil Question #5
I use 5W30 in the fall and 30W in the heat of summer. I've found my small engines; 12HP Kohler Commander, 6HP Briggs Intec and 13HP Tecumseh Commercial all "use" more of the multi-vis oil than the straight 30W.I keep 5W30 in my 13HP Honda generator year round, as it is seldom used, usually during winter power outages :mad:
   / Oil Question
Thanks for the replies. It's a B&S v twin 21hp. The mower it's on is too large to be moved manually.
   / Oil Question #7
I use 10W30 in all my mowers
   / Oil Question #8
I use 5w30 in all my engines except for 10w40 in the 1983 Benz speced for that.
For your engine, I'd use 5w30. If you can get 0w30 and really need to start it in winter, get it and use it all year round. Use synthetic and you'll only need to change once/year. If I could get 0w30, that's what I'd be using in all the engines (except that old Benz). I can occasionally find 0w40 or 5w40 for the Benz and use those instead of 10w40. Change it once/year, too.
I worked in the lube oil manufacturing business for a little bitty oil company that has since acquired another. Call themselves EM now. Done the viscosity calcs and have seen research work. 0w is better than 5w or 10w with synthetics. Main problem with lower xxxw oils in the old days was it took gobs of additives, that would break down, to get the low xxxw. Not so with synthetics.
Ralph
   / Oil Question #9
I use 5w40 Rotella in all my gas and diesel engines. Never had a problem. I think my Honda push mower loves it! Power washer, generator, and push mowers all get the same oil.
   / Oil Question
Scrounger,
Do you use the synth T type? I take it that the diesel oil certification satisfies the gas engine oil reqs but not the other way around?
UNUSED KIVEL 3500# PALLET FORKS (A54757)
UNUSED KIVEL 3500#...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
