Oil qauntity for 3x20 - manual vs. label on hood
   / Oil qauntity for 3x20 - manual vs. label on hood #1
HuskerInVA
Loudoun County VA
JD 3520, '71 Case 580CK TLB
I know this applies to my 3520, but I'm not sure about other 3x20 machines.
I recently did my 50 hour oil/filter change. The manual says 5.1 quarts for oil/filter change. Under hood label says 4.5 quarts for oil/filter change.
I didn't see the difference until after I changed my oil. I drained, replaced filter, and filled with 5 quarts. When I poured the old oil back into the 1 gallon container for recycling it all fit. I was initially concerned that I didn't let it drain long enough -- but I was way over filled on my dipstick. I ended up draining about 1/2 quart to get to the full line on dipstick.
Long story short. Under hood label of 4.5 quarts appears to be correct. 5.1 quarts in manual appears to be wrong.
   / Oil qauntity for 3x20 - manual vs. label on hood #2
I found glaring mistakes in my JD 4300 manual too, and wish Deere had better editors. However, the manual probably is assigned to those who just copy from old and do not really know the intimacy of the equipment they are 'manualling' at the moment. Too much room for error, for us to find later, IMO.
I find the CD to be real helpful, albeit there may be mistakes there too. When, if, I trade up, I will order the CD to work from.
Glad this error was only a minor inconvenience to you, and that you noticed it early.
beenthere
Yep -- it wasn't a great inconvenience for me, but hopefully I can save someone else a little time and mess in the future.
   / Oil qauntity for 3x20 - manual vs. label on hood #4
Does your 3520 have one drain plug or two like the 3720?
I put in 6 like my manual says and it looks to be about right, just a 1/4" short of full prior to complete drainback.
Only 1 drain plug on the 3520 that I could find. Manual was correct on that one.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2017 FREIGHTLINER...
1984 GROVE CRANE (A52576)
1984 GROVE CRANE...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
Enclosed Trailer (A52377)
Enclosed Trailer...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
JOHN DEERE F725 LOT NUMBER 101 (A53084)
JOHN DEERE F725...
