Oil & Fuel oil pump problem
   / oil pump problem #1
fred jr
1972 kubota l-175
l-175 kubota will the oil pump stop pumping after it runs for 1 hr and the motor starts knocking, or is the oil breaking down?
   / oil pump problem #2
I have never seen an oil pump stop working then start working again. Most of these oil pumps are gear driven off the front geartrain and are very reliable. Possible causes: low oil level, incorrect grade of oil, debris covering and uncovering pick-up screen, pick-up tube loose, sucking air on supply side of pump, worn out pump, worn out bearings, sticking oil pressure regulator, etc. Put a mechanical gauge in an oil galley and watch pressure hot and cold at various rpm's. Before this question was even asked, I would have changed oil and filter to evaluate. How many hours on this engine? How many hours since last oil change? Philip.
   / oil pump problem
Thanks a lot Philip, just know getting into the problem. Changing oil and filter is the first thing I will do.... Fred Jr.
   / oil pump problem
Thanks a lot Phillip, just now getting into the problem. First thing I will do is to change the oil and filter. fredjr..
2008 Mazda CX9 (A50324)
2008 Mazda CX9...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
Portable Calf Creep Feeder (A50515)
Portable Calf...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
UNUSED AGT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SKID...
Navigator 4000 4,000lbs Forklift (TRUCK MOUNT) (A52128)
Navigator 4000...
