Oil & Fuel Oil Pump Gasket
/ Oil Pump Gasket #1
Jinma284
Lady Lake, Fl.
Jinma 284
I need an oil pump gasket for my Jinma 254 with a Y385 engine. They are paper thin and Jinma Dealers can not get them. You have to buy the complete oil pump. Any ideas where I could get gasket material that thin. Pat
/ Oil Pump Gasket #2
Perhaps this is what you are looking for. They have many other materials too.
McMaster-Carr
You could also check you local auto supply store.
/ Oil Pump Gasket #3
/ Oil Pump Gasket #4
/ Oil Pump Gasket
I will check with NAPA and Carquest tomorrow. I've just never seen a gasket as thin as the one I need. Pat
/ Oil Pump Gasket #6
On NAPA's web site they have material down to 1/64" (0.0156"). How much thinner does it need to be?
Store Locator | NAPA Online
If you need to go thinner than 1/64", I would consider the Loctite 515 mentioned above. It is very good product.
Loctite® Gasket Maker 515 Flange Sealant is a flexible, gasketing material for use on rigid machined flanges with less than 0.015" gap. OEM approved use where OEs specify 515 or anaerobic gasket (cures in absence of air). Eliminates preformed, pre-cut, paper, rubber and cork gaskets.
Here is the technical data sheet on 515...
http://207.250.200.229:8080/1/doc?id=26260
/ Oil Pump Gasket #7
Measure the thickness of heavy duty aluminum foil to see if it's about the right thickness. It's real common on IR oil pumps. My hand made ones just never did look quite as neat as the factory cuts.
/ Oil Pump Gasket #8
Can't do it, like I mentioned earlier if you go without a gasket, it'll bind the pump.
In a pinch I've used heavy paper with success, the kind that they use on covers of spiral bound notepads seems to be the right thickness.....Mike
/ Oil Pump Gasket #9
In this application, if you use paper, I suggest you install a gasket material that's labeled WOG (water, oil, gas). Automotive stores usually keep gasket material.
/ Oil Pump Gasket #10
For thin gaskets on things that allow high clamping pressures, dead soft copper sheeting works pretty well. Hobby shops carry thin copper sheet for craft use, usually dead soft annealed. If you don't have high clamping pressure you'll be better off with a paper gasket treated with gasket compound. You just have to take a micrometer and measure various hard papers like file folder stock until you find the right thickness.
/ Oil Pump Gasket #11
lots of options like other mentioned. I have used cereal boxes, pop case boxes also work well for thicker gaskets. Though for this particular gasket I'm mot familiar with it. aluminum foil seems like it might tear easily but the soft copper sheet might be good.
Mark
/ Oil Pump Gasket #12
What was the final outcome?
/ Oil Pump Gasket
I just didn't have the nads to try something that might cause me more problems. I've had enough as it is. Decided to order a new pump.
Pat
/ Oil Pump Gasket #14
People, please do not use gasket maker for an oil pump gasket. When it squeezes out (and it will, make no mistake about that) those little balls of RTV snot will be pumped throughout your engine if your oil filter has a bypass in it.
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
CAT CB34 (A60462)
CAT CB34 (A60462)
2017 Kubota L3901 (A64126)
2017 Kubota L3901...
Sakai SW354 (A64126)
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
