oil problem solved maybe
/ oil problem solved maybe #1
Jeremy_R
oil problem solved maybe. I found that the pressure sensor is bad. The one that was in there does not apear to be stock. It had 1/8 NPT threads on it. Can anyone tell me what the right threads are for the sensor so I can get the right metric to npt adaptor. I'm going to forget the sensor and install a oilpressure gauge.
Jeremy
/ oil problem solved maybe #2
If the threads are already npt why convert it back. Get a gauge that goes up to 100 pounds.
It is for sure solved. I got a metric adapter kit for my oil pressure gauge. Fired it up and up came the oil pressure. I'm going to repluumb it with copper tubing and put a tee in to put a new sensor just for grins.
Jeremy
/ oil problem solved maybe #4
How many pounds do you have? My 3 cyl. Buck has about 85 I think and I have a copper line on it. The other one doesn't have a gauge yet, but will one day.
It is running around 80 psi. I was able to put a tee in it and hook up the idot light also. Installed the copper line today and every thing is good.
Jeremy
SET OF (4) METAL LOCKERS (A64281)
SET OF (4) METAL...
6' 3Pt Disk (A66285)
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
(2) UNUSED 25X10.00-12 TIRES W/ 4 LUG RIMS (A64280)
(2) UNUSED...
10' Dozer Blade (A64119)
10' Dozer Blade...
