oil problem solved maybe
   / oil problem solved maybe #1
Jeremy_R
oil problem solved maybe. I found that the pressure sensor is bad. The one that was in there does not apear to be stock. It had 1/8 NPT threads on it. Can anyone tell me what the right threads are for the sensor so I can get the right metric to npt adaptor. I'm going to forget the sensor and install a oilpressure gauge.
Jeremy
   / oil problem solved maybe #2
If the threads are already npt why convert it back. Get a gauge that goes up to 100 pounds.
It is for sure solved. I got a metric adapter kit for my oil pressure gauge. Fired it up and up came the oil pressure. I'm going to repluumb it with copper tubing and put a tee in to put a new sensor just for grins.
Jeremy
   / oil problem solved maybe #4
How many pounds do you have? My 3 cyl. Buck has about 85 I think and I have a copper line on it. The other one doesn't have a gauge yet, but will one day.
It is running around 80 psi. I was able to put a tee in it and hook up the idot light also. Installed the copper line today and every thing is good.
Jeremy
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2016 CHEVROLET 2500 TRUCK (A51247)
2016 CHEVROLET...
