oil pressure
   / oil pressure #1
slammer3364
Bronze Member
Jinma 284
Just looked at the thread about oil pressure.My Jinma 28 has great oil pressure until it runs for about a half hour then the gauge steadily drops,but still maintains pressure but drops close to the red mark I was thinking I just have a bad guage. Any tips Thanks
   / oil pressure #2
Only tip I know of is to get an external gauge like is sold at most auto supply stores. Better safe than sorry.
   / oil pressure #3
Is your radiator spotlessly clean? Is your fan belt tight? What kind of oil are you using? How is your coolant temperature?
   / oil pressure #4
Highest oil pressure when cold is normal. That's when the oil is thickest, hence hardest to pump. As the engine warms up, the oil thins. It's not so hard for the pump to circulate it. Normal oil pressure at operating temperature should be around 30 psi, but a trusted dealer tells me that there's no danger lower than that - until you get to 7 psi. If/when you drop below 7 regularly, you might want to replace the otherwise inexpensive sending unit first.
//greg//
   / oil pressure
I always run Valvoline 10 w 30 radiator is clean belts are tight Temp usally runs about in the middle of guage Thanks Slammer
   / oil pressure #6
Most everyone uses 15w-40 rated for diesel engines. Like Chevron Delo or Shell Rotella.
   / oil pressure #8
First do an oil change and get the proper oil in the machine before anything else. Bob listed a couple nice choices. Just make sure it is a diesel rated oil.
2018 HINO 195 16FT BOX TRUCK WITH LIFT GATE (A53426)
2018 HINO 195 16FT...
2012 Kubota M108S (A50123)
2012 Kubota M108S...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
9202 (A50322)
9202 (A50322)
