Oil Pressure Tester
   / Oil Pressure Tester #1
Polo
Alabama
Case IH 7120, IMT 529
I own a New Holland TN75DA. I am hvaing some erratic problems with my oil pressure light so I need to check the pressure with a manual gauge. I purchased a guage with multiple adaptors at an automotive shop but none of the adaptors work. Does anyone know of a tester kit that does provide an adaptor to fit a TN75DA or by change know the thread and size of the oil pressure port.
   / Oil Pressure Tester #3
Quite a few non US engines do not use tapered pipe thread; instead using straight thread (6MM, 8MM) with a O ring or copper washer at the shoulder to seal. To ID the hole try some metric bolts 6MM X1.0 or 1.25 or 8MM x 1.25 or 1.5, or as said above, find one of the assortments
   / Oil Pressure Tester #4
Ditto on the sunpro set.. i got one at auto zone.. etc.
Soundguy
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
6" & 10" I BEAMS UP TO 40' LONG & MISC (A51247)
6" & 10" I BEAMS...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
