Sep 25, 2021 / Oil pressure start up time #1 orezok Super Member Joined Jan 30, 2004 Messages 6,193 Location Mojave Desert, CA Tractor Kubota B7800 I have a B7800 with a 1505 engine. How long does it usually take for your tractors oil pressure idiot light to go out at cold start in moderate temps?
Sep 25, 2021 / Oil pressure start up time #2 Jerry/MT Elite Member Joined Feb 2, 2008 Messages 3,141 Location North Idaho-The Palouse Tractor New Holland TD95D, Ford 4610 & Kubota M4500 A few seconds. with the specified lube oil in all temps. PS Is that a Polish Eagle in your Avatar?
Sep 25, 2021 / Oil pressure start up time #3 Roadworthy Elite Member Joined Aug 24, 2019 Messages 4,045 Location Southeast Washington Tractor Kubota L2501 HST, By the time the tractor gets up to idle speed the light is out - about like a car.
Sep 25, 2021 / Oil pressure start up time #4 4570Man Super Star Member Joined Apr 7, 2015 Messages 19,190 Location Crossville, TN Tractor Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers. Sometimes the light stays on continuous at idle. Mine goes off immediately with a slight rpm increase.
Sep 26, 2021 / Oil pressure start up time #5 C Chilliwack Murray Gold Member Joined Sep 9, 2017 Messages 417 Location Canada Tractor Kubota 7510, 6000, Industrial JD400 Backhoe It really shouldn’t stay on. It may just be a faulty switch so hookup a temporary gauge at least and see what’s actually happening. If you have low oil pressure a cheap repair may save you from a major engine failure.
Sep 26, 2021 / Oil pressure start up time #6 ljjhouser Veteran Member Joined Oct 25, 2018 Messages 1,387 Location Midwest - Ozarks Tractor Kubota L4701 About 5 seconds after startup. But you are in the desert - maybe it should go out before you put the key in!
Sep 26, 2021 / Oil pressure start up time Thread Starter #7 OP orezok Super Member Joined Jan 30, 2004 Messages 6,193 Location Mojave Desert, CA Tractor Kubota B7800 Jerry/MT said: A few seconds. with the specified lube oil in all temps. PS Is that a Polish Eagle in your Avatar? Click to expand... Yes it is!
Sep 26, 2021 / Oil pressure start up time #8 WranglerX Super Member Joined Apr 6, 2018 Messages 5,605 Location A Little Bit West Of Yosemite NP Tractor MF GC1715 Just a few seconds....
Sep 26, 2021 / Oil pressure start up time #9 S Smokeydog Elite Member Joined Jan 20, 2019 Messages 3,213 Location Knoxville, Tennessee Tractor Kubota B26, M59, M5030DT Yep just a few seconds. Had a similar issue before getting no light. Replaced the pressure switch.
