Oil Pressure Line Missing
/ Oil Pressure Line Missing #1
MIKE R
Elite Member
CANADA
Many
I am working on finishing the restoration on my Case Sc. I am going to order new gauges for the old ones don't work and aren't hooked up. When I got the tractor the oil pressure line was not on the tractor. I looked over the engine to see if I can find the sender unit. Any ideas where the sender would be located would be appreciated.
/ Oil Pressure Line Missing #2
Mike I can't tell you the exact location but near the oil filter base a 1/4 or 5/16 plug may be in oil tube and some times just a small line is run to pressure guage.
Check in the repair book of your tractor maybe location is listed. Then sometimes go to library many carry several books on tractor repair.
Have a Allis Chalmers and oil pressure guage is screwed directly into the filter base.
ken
I'll take a look in the repair book and see if I can see any line from the the pump and follow it out. It doesn't have a oil filter just a screen.
I think I found where the line should be. I was looking at a video of a Case Sc for sale and was able to see where the line connects. Took the plug out while the tractor was running and oil came out.
Here's a photo of where the line should go, right above the starter ~ the gray colored plug.
ROANOKE LONG ARM DITCH BANK MOWER (A63291)
ROANOKE LONG ARM...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-350...
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
Pat's QH and hydraulic top-link.
Pat's QH and...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
