Oil Pressure Light
/ Oil Pressure Light #1
mrigney
LS XR4046
I have a 2016ish XR4046. Roughly 600 hours on it. No issues w/it. The last two times I've bush hogged, the oil pressure indicator light has come on after about 45 minutes. Haven't noticed anything in terms of performance. Both times, I went ahead and shut it off, let it rest a while, checked oil levels, and it was fine (no indicator) when I started back up. It will eventually come on again, though. I probably am due for an oil change, but given the oil levels are fine, I wouldn't have expected an oil pressure issue.
I'm an inexperienced diesel engine person, but am willing and able to learn. What should I be looking for here do diagnose the issue?
/ Oil Pressure Light #2
Either put a real gauge on it to see if it really is dropping out or guess that the sensor is going bad and replace it. On a Dodge it would be the sensor 95% of the time and $20 to buy one. Have not had that problem on my XG with 850 hours so far.
It could be a bare wire to the sensor shorting to ground but I would NOT expect just a short break time to fix that.
Maybe a clogged filter but the bypass in the filter should prevent that.
Last thought how hot is it getting? My temp gauge is flaky so I added a engine block temp gauge. Might not hurt to clean the radiators.
2012 International (A59230)
2012 International...
3 Bottom Plow (A65640)
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
429888 (A61165)
429888 (A61165)
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
