Oil Pressure Light
   / Oil Pressure Light #1
mrigney
LS XR4046
I have a 2016ish XR4046. Roughly 600 hours on it. No issues w/it. The last two times I've bush hogged, the oil pressure indicator light has come on after about 45 minutes. Haven't noticed anything in terms of performance. Both times, I went ahead and shut it off, let it rest a while, checked oil levels, and it was fine (no indicator) when I started back up. It will eventually come on again, though. I probably am due for an oil change, but given the oil levels are fine, I wouldn't have expected an oil pressure issue.
I'm an inexperienced diesel engine person, but am willing and able to learn. What should I be looking for here do diagnose the issue?
   / Oil Pressure Light #2
Either put a real gauge on it to see if it really is dropping out or guess that the sensor is going bad and replace it. On a Dodge it would be the sensor 95% of the time and $20 to buy one. Have not had that problem on my XG with 850 hours so far.
It could be a bare wire to the sensor shorting to ground but I would NOT expect just a short break time to fix that.
Maybe a clogged filter but the bypass in the filter should prevent that.
Last thought how hot is it getting? My temp gauge is flaky so I added a engine block temp gauge. Might not hurt to clean the radiators.
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2008 Saturn VUE XE SUV (A53117)
2008 Saturn VUE XE...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
