Oil pressure gauge saved the day
   / Oil pressure gauge saved the day #1
90cummins
Veteran Member
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
In 1996 I purchased a Snapper Pro Hydro 52 walk behind with a 16hp Briggs Vanguard which currently has approx 520 hours on it.
For years I thought about adding an oil pressure guage but it was always a low priority.
Well 3 weeks ago I installed a 100psi gauge.
Full throttle cold it runs 70 psi and hot it runs 28 psi with Mobil1 10w30. Idle hot is 18~20 psi.
The other day I was mowing a bank like I have for years when it went over the edge and became stuck so I idled it down so I could access the situation and hopefully back it out.
As I was pondering the situation I noticed the oil pressure was zero.
I quickly shut it down and got my Ford 1720 so I could pull it out of the ditch.
Had I not installed the pressure gauge I most likely would have let it run and attempted to maneuver it out of the ditch.
The interesting thing is that it was not in a position that I would have considered extreme, but apparently it was the perfect position to move all oil away from the oil pump pickup.
That guage most likely saved me several hundred dollars.
Tim
   / Oil pressure gauge saved the day #2
I blew up one mower doing that.
Switch to a 2 cycle engine (a snapper) because of it.
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
Pintle Hitch (A51573)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
