Oil pressure gauge question
   / Oil pressure gauge question #1
Cord
Richfield, Wi
Resident Architect
Those of you that have added a oil pressure gauge, what kind of readings are you getting?
Cold start
Cold engine under load
Hot engine idle
Hot engine under load
   / Oil pressure gauge question #2
I wouldn't try to over-analyze that oil pressure. any pressure reading is good. An oil light goes out at about 3-3.5 psi.
I want to order a gauge for my tractor. I need to keep the gauge under the max pressure, but the narrower I can keep the range, the easier it will be to read the pressure. 3 lbs is pretty low!
   / Oil pressure gauge question #4
You can't go wrong with an 80 psi gauge, and expect to see anything between 10-60 psi.
   / Oil pressure gauge question #5
Norm,
Isn't it possible to adjust oil pressure up with the flange nut behind the oil filter? I believe it slows down the oil return and boosts the pressure side...I've never done it, just heard you can.
Mark
   / Oil pressure gauge question #6
"Isn't it possible to adjust oil pressure up with the flange nut behind the oil filter? I believe it slows down the oil return and boosts the pressure side...I've never done it, just heard you can."
I've never done it either, but who knows what the correct adj. would be? The only oil pressure problems I have ever had on a vehicle were in the sending switch and I've had 15 old cars and 1 old tractor over a 48 year period.
Well it's the sending switch that I'm trying to diagnose. Good cold pressure, but the oil light comes on after 10 min of running when the oil starts to thin out. The engine sounds fine which is why I'm suspecting the sender. Of course, the two cylinder clack would mask any rod knock so who knows. There could be another issue which is why I need to know what the actual pressure is.
1110d
   / Oil pressure gauge question #10
I have a 3110d and the following are my oil pressure observations.
Cold Idle and working-Approx 75
Warm and working-Approx 50
Warm at Idle-Approx 25
Hope that helps.
Jim B
2018 TowMaster T-12D 23ft T/A Flatbed Equipment Trailer (A51692)
2018 TowMaster...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2022 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A51692)
2022 Mercedes-Benz...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2016 FREIGHTLINER CASCADIA SLEEPER (A53426)
2016 FREIGHTLINER...
