Oil pan removal kioti ck 35
   / Oil pan removal kioti ck 35 #1
Greatone
202 kioti ck 3510 se
Is front drive shaft removal nessacary for oil pan removal
   / Oil pan removal kioti ck 35 #2
Just going from memory on my former CK40HST, I'd say yes.
On the NX45HST, the drive shaft goes through the center as well.
I've pondered the process of a what if scenario.
If it is necessary to repair a small leak, look at the clearance from the drive shaft to the pan.
Maybe it's possible to drop it a bit, clean pan and insert new gasket?
If you have a contact with your dealer, I'd ask him if it's OK to speak with one of the techs for their tricks and tips.
I do that quite often when I go to get supplies. It's my excuse to stay in their memory bank that I'm one of their customers and support their shop.
Yeah, I'm shameless when it comes to asking questions of their tech...heh....heh....
   / Oil pan removal kioti ck 35 #3
Pulling the front drive shaft to remove a split sump oil pan isn't a big deal on any tractor in reality. You don't have to remove the output section, just pull the shield back, remove the coupler and allow the shaft to swing down and remove the pan.
2013 PETERBILT 367 (A48992)
2013 PETERBILT 367...
12FT 6IN BOLSTER (A48992)
12FT 6IN BOLSTER...
2 Ton Gravity Bin (A49251)
2 Ton Gravity Bin...
2014 Dodge Charger Sedan (A46684)
2014 Dodge Charger...
1993 John Deere 6300 2WD Tractor (A49251)
1993 John Deere...
8ft QA Snow Pusher (A49251)
8ft QA Snow Pusher...
