MikePA
Super Moderator
Has anyone ever used one of these? Opinions?
Moroso Oil Pan Heater
While the block heater heats up the coolant around the cylinders to make starting easier in cold temps, it has very little effect on the engine oil, unless you plug in the block heater immeadiately after shutting down the engine for the day. This oil pan heater can reduce warm-up and EBP valve on times as well as cure the sluggishness associated with cold, thick oil. The 5X7 inch pad adhears to the side of the oil pan and has a 22" cord. The pad has a 400 watt rating and will raise the oil temperature on a 5-quart sump from 60 to 160 degrees in 30 minutes. I suggest plugging in the Oil Pan Heater at the same time as the block heater--about 2 hrs before driving, depending on the temperature.
The pad needs to be attached to paint-free metal and the edges sealed with a high-temp silicon sealer (not included)
Moroso Oil Pan Heater: $60.00
