Oil pan heater
   / Oil pan heater #1
wayupnth
Maine
Anyone use an electric oil pan heater on a diesel UV? I have a diesel gator that needs some significant help starting on these cold days. No block heater and I'm not sure if I want to go that route. Any experience would be helpful. Also, what size is appropriate?
   / Oil pan heater #2
I have a couple of magnetic oil pan heaters that work great. They are made by Philips and Temro Industries Inc., out of Eden Praire, MN. It's called a "ZEROSTART" Super Heat Magnate, 120V, 60 Hz, 200W. Ive used them on my 8N's and they seem to do the trick.
   / Oil pan heater #3
They have a 200 watt magnetic at tractor supply for around 30 if I recall. Only concern with a utv is scraping it off with brush/snow unless you plan on just taking it off when you use it.
   / Oil pan heater #4
I use a magnetic 100W heater on my Kubota 7100. The oil pan is exposed and it is easy to attach and remove the heater. I also have a Kubota RTV 1100. Its oil pan is behind a skid plate so I got a 50W patch type heater, attached it to the bottom of the pan and ran the power cord up into the cab. Just open the door and plug an extension cord into the heater plug. Obviously it takes the 50W heater some what longer to warm up the oil but both heaters work well.
   / Oil pan heater #5
Curious. Are you running synthetic oil?
   / Oil pan heater #6
I have always used 15W40 diesel oil in both the B7100 & the RTV1100. I change the oil and filter every 50 hours.
   / Oil pan heater #7
Try Rotella T-6 synthetic 5-40 available at Wallyworld. I think you will be pleased with the easier starting. 50 hour OCI are really conservative, I think you could justify twice that long and the additional cost of the synthetic would be almost a wash.
Just my suggestion, take it or leave it.
I just (for the first time) put it in my XUV diesel and it starts nicer and runs better.
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
2014 International Durastar 4300 SBA 4 x 2 Water Truck, VIN 3HAMMMMN4FL510006, Cummins Turbo Diesel (A59076)
2014 International...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
Generac XG8000E Generator (A55973)
Generac XG8000E...
