Oil Pan Drain Plug
/ Oil Pan Drain Plug #1
kells
I cannot get the drain plug off on my Iseki, Who ever tighten it last time just cranked on this thing. The head is now stripped as well. I have tried Vise grips,heating the plug and banging on a smaller socket but i cannot budge the plug, any other ideas?
/ Oil Pan Drain Plug #3
Mine was so tight when I got it I had to take a big crescent wrench and a hammer to loosen it. Might be the refurbishing people overseas are using an air wrench?
Anyway, keep putting PB blaster on it for a couple of days and then try it again. If it is rounded off, you might end-up dropping the oil pan and easy-outing it. Also you might try grinding a slot for a large screw driver, or welding something on it and using that to turn it. Good luck.
/ Oil Pan Drain Plug #4
Pipewrench and a cheater bar.
/ Oil Pan Drain Plug #5
Use a pipe wrench, it won't slip like vise grips.
Thanks guys I will give all of them a try this week and hope one of them works. Thanks again.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
UNUSED RANCH HAND DIAMOND PLATE REAR BUMPER (A64280)
UNUSED RANCH HAND...
CATERPILLAR DP40 STRAIGHT MAST FORKLIFT (A64279)
CATERPILLAR DP40...
1995 CHEVROLET 3500 FLATBED DUALLY (A64276)
1995 CHEVROLET...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
