Hi. I've always been exact in filling any engine with oil be it car, cycle, mower, etc. My Kubota takes 3.5 qts. with the filter. Yesterday I put in about 14 more ounces than called for...almost 4 qts. It reads just a hair over the FULL line on the dipstick. Should I drain that much out or let it go? I have always read that overfilling causes higher pressure and can damage the engine. It is really not much trouble to loosen the plug and let it drip out in a measured cup. Thank you for your opinions......I just checked my oil level and it is almost 1/2" above the FULL line so I am going to drain 14 ounces out. I've never had a problem with any engine I've owned so I was worried. Have a good day.
