Oil lube rant
   / Oil lube rant #31
For disposal we can set out 2 gallons per week with the trash and they will recycle it.... haven't seemed to clue into the new '5 quart' containers that oil comes in now ;)
A friend of mine that does not have curbside disposal puts his oil in 5 gallon gas cans. Easy to transport and since he keeps the container every time he doesn't have to worry about disposing of it after dropping off the oil at a collection piont.
   / Oil lube rant #32
Charlz, that's a very progressive location that will do that.:) How much is your garbage collection fee? We pay $40 per month and feel lucky when the truck shows up once a week and dumps our trash can.:rolleyes:
   / Oil lube rant #33
I really HATE to use terms like "Grease Monkey", because I have a great deal of respect for competent service techs, but most of the lube shop people are NOT service techs.
The cost, price, profit, competition equation probably dictates that they use unqualified and barely trained people for this - in fact one of my sons did it for a very short time in HS.
I have NEVER trusted anyone else with my brakes, not since Dad used to do my bicycle brakes.
It has carried over to oil changes and MOST other service work.
I like to "get under there" and browse around for other stuff that might need attention - I don't LIKE to, in fact I hate the squirming around on the driveway part.
This is just something I feel I have to do myself - I can't outsource ALL my life and living (-:
   / Oil lube rant #34
Ditto that.. the lube places in my town are all pretty much minimum wage, hire-you-off-the-street places.. one day you are a burger flipper.. one day you are a 'lube tech'.
soundguy
   / Oil lube rant
soundguy
I have to agree with you and many post here ,but at times we are stuck between a rock and a hard place.
Was in Ga pulling a 30ft travel trailer lost a break line without trailer attached,pulled into a prominent auto chain to have it repaired,stood outside of bay while they worked on it.
They replaced the line from the master cyl to the rear tee in three sections instead of making up one solid line,when he went to bleed the brakes he stripped it using an open end wrench,instead of a six sided box wrench, next he attacked it with a pair of water-pump pliers then he broke it off.
Now I need a new wheel cyl. they could not do it because it was nearing closing time and they did not open on Saturday,I asked if anyone was open and he pointed up the street to another repair garage.
I went to the garage and asked if he could do the job and set up to bring the truck in the morning,after removing the drum I noticed that the axle seal was leaking and asked him to replace it, then he starts to remove the differential cover and I asked him why,he says so he can take the axle out I told not to that it was a full floating .
He goes and gets his boss and and we have a discussion on how the axle comes apart to replace the seal he then ask the other mechanics if they ever worked on this type of axle and all he got was a blank look from them.
After another discussion with him he agreed to take it out the way I said,he gets the axle out and the seal and my real estate agent comes over to pick me up to go look at a house,I told the mechanic to put some oil where the seal rides and to assemble it in the reverse order,when I returned he was done the left side and was ready to install the right side without putting oil where the seal rides I asked if he had lubed the left side and he said yes.
Now it's time for the bill, 7 hrs labor @ $70 =$490 parts $140 total $630 for a job that should have taken 3hrs at the most thats in addition to the $150 to replace the brake line at the other place.
Two days goes by and the left rear seal starts leaking,back to the garage you guessed it he did not lube the seal when he did the assembly.
The thing that PMO the most is getting charged $70 an hr for a mechanic and I have to show him how to do the job!
   / Oil lube rant #36
it's at that point when you know you should be doing the repair yourself.. when you have to tell them how to do it!
soundguy
   / Oil lube rant #37
It about $40 per _quarter_ for weekly 'unlimited' pickup. They are switching to sideloaders so I am not sure if you can just pile up the 'unlimited' or if you have to rent more cans (additional 95 gallon cart is $1.50 per month). They are just now switching so time will tell. White goods they recycle but you have to pay extra for, just call the day before and have it out before 6am. I just got rid of my old hot water heater for $27 and it was gone by 7am the next day. I think freon containing white goods you might have to take somewhere or they charge more to pick up.
   / Oil lube rant #38
Oh and they have certain days for free leaf pickup in the fall as well as dates for free Christmas tree pickup. They have green waste diversion at the landfill so all this stuff is 'recycled'. Also our trash service is through the county so it's likely I am paying for some of this in my taxes as well as the trash bill.
   / Oil lube rant #40
I stopped using the "quick" stops about 10 years ago after looking at my upper ball joints and seeing the grease just squirted in the direction of the zerk. Oh and the zerk was dirty like it hadn't even been wiped. I also have to assume that they couldn't reach the uppers and therefore checked them off.
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
