Oil Light
/ Oil Light #1
lateralex
My boss owns a 1968 Ford 3000 tractor. He told me the oil was flickering on the other day. He checked the oil level and it was low. After refilling it the light is now on full time. He doesnt seem to think he has a leak. Could it just be the sensor? Are oil gauges based on volume or pressure?
/ Oil Light
/ Oil Light #3
Oil pressure gauges on most things are just relying on pressure and assuming good flow associated with the pressure.
The problem you describe could be a bad oil pressure sending unit or a wiring connection going to the sending unit.
You can use a pressure gauge screwed in in place of the sending unit and check for actual oil pressure, you might not have much, which is a bad thing. The oil pressure lights usually lights up at under 10lbs of oil pressure or so.
Ben
/ Oil Light #4
Ben
/ Oil Light
Thank you for the prompt reply! Would you happen to know the ballpark of proper oil pressure for a '68 Ford 3000?
/ Oil Light
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
Woods Rotary Cutter (A63116)
Woods Rotary...
Ag Leader Integra Screen (A63116)
Ag Leader Integra...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
2020 Case IH 475 Speed Disk (A63109)
2020 Case IH 475...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
