Oil & Fuel Oil level sight glass
   / Oil level sight glass #1
jgreen
Mid MO
Branson 2810 w/FEL, JD 40S
Hi Folks,
I had an oil leak on my 2810 this past weekend. The oil level sight level indicator on the rear end was leaking. I grabbed it and it was real loose and I was able to pull it out with my fingers. I glad I noticed the oil leak it when it was sitting in the shed not out in the field! The sight glass is made of plastic and has a rubber sleeve around it (not a o-ring) and looks as it may have had gray type of adhesive on the edge. My old one does not fit tight in the hole on the rear end. The hole is a smooth machined hole. I have a new sight glass ordered but will not probably have it until Thursday, probably Friday due to the July 4th holiday. The dealer suggested I out some silicone gasket sealer on the old one (clean it and the hole first) and re-install. Any ideas? I know the silicone gasket sealer is good stuff but I sure would like to make sure it or the new one does not come loose again.
Thanks
   / Oil level sight glass #2
I had a slight oil leak around my sight glass. I contacted my dealer and they also recommended rtv silicone sealant. I did have to pry it out. I seperated the sight glass from its gasket and cleaned all surfaces. I applied the silicone to the inside of the gasket and inserted the sight glass. Then I put some sealant in the hole and snapped the sight glass assembly back in to place. So far,so good.
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
2016 TAKEUCHI TB290 EXCAVATOR (A51246)
2016 TAKEUCHI...
23169 (A50324)
23169 (A50324)
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
