Oil Level measuring
   / Oil Level measuring #11
The owners manual for the LA120 says to screw in dipstick to check engine oil level (page 25 of the on line manual).
Yikes, I have the manual and looked and never found it. So I just went out to the garage to get it. I turned to page 25 and guess what? There it was.
Again, thanks everyone for your help.
   / Oil Level measuring #13
The small difference in oil level between the two methods can't be significant to the operation, in my opinion.
   / Oil Level measuring #14
@beenthere The difference in the two levels would result in being overfilled about 6-8 ounces. On some engines would be enough to cause mosquito fogging on slopes.
In my particular engine, when I do it both ways, one says full the other says add.
   / Oil Level measuring #16
About the same on my Z920...the manual specifies to not thread the cap.
I reckon your mower may have the same Kawasaki engine my Z920 has
Actually, mines is a B&S and you have to screw it in, but we both get the same variance when we do it wrong.
   / Oil Level measuring #18
So... if fogging on slopes then still not a major problem. just sayin...
   / Oil Level measuring #20
Unless in some cases it also caused it to break the reed valve in the breather assembly requiring complete engine teardown to replace the breather on the inside of the block.
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2012 BMW 328i (A50324)
2016 Ford Fusion SE (A50324)
2016 Ford Fusion...
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
