oil level in transmission eye glass
   / oil level in transmission eye glass #1
deereman63
deere 2210
When i m using the tractor there is no oil showing in the transmission eye glass. /forums/images/graemlins/shocked.gif But when I switch off the level comes back to half way. Should I be adding more oil ?
   / oil level in transmission eye glass #2
My 2210 does the same. I have found that a very small amount; probably an ounce or two is the difference between the top and bottom of the indicator. I don't think it is anything to worry about.
   / oil level in transmission eye glass #3
I think the proper level is reached by filling or adding fluid when the tractor is not running. In other words, I think you have the right amount in it.
Jd fanatic did you get my email reply on the phd?
   / oil level in transmission eye glass #5
No, and I was looking forward to it. How do we go about this? /forums/images/graemlins/confused.gif
JDfanatic i cant get the pm system to send out messages. so I have set up an account at hotmail... odoacer476@hotmail.com.
That was the year that the lad finally was able to finally close Rome down. so could you send your question there
thanks
   / oil level in transmission eye glass #7
I believe the 2210 became available around Nov/Dec 2001, and I know mine was one of the first purchased in Jan 2002. In fact, mine does not have the "HST" decal on the side shelds as you see in the pamplet, but I have noticed it on all the new models.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
