Oil leak
   / Oil leak #1
DrRon
Jones, OK
JD 3020, JD 830, JD - A
I have a 1948 JD tractor leaking oil from the left axle. There is a grease zerk on top of the axle. What could be the reason?
   / Oil leak #2
Hardened and worn out seal. It's a 1948 after all and seals don't last forever. '48 makes it an antique.
   / Oil leak
Any idea of cost of repair?
   / Oil leak #4
Your nearest tractor shop should give you a good idea of cost to repair. Do the other side at the same time….😉
2016 Ford Taurus AWD Sedan (A53424)
2016 Ford Taurus...
1996 LUEHAUF TRI AXLE STEP DECK (A53843)
1996 LUEHAUF TRI...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2014 TEXAS PRIDE GOOSENECK (A53843)
2014 TEXAS PRIDE...
2 MONITORS:  HP & SAMSUNG (A53843)
2 MONITORS: HP &...
