Oil leak
   / Oil leak #1
DrRon
Jones, OK
JD 3020, JD 830, JD - A
I have a 1948 JD tractor leaking oil from the left axle. There is a grease zerk on top of the axle. What could be the reason?
   / Oil leak #2
Hardened and worn out seal. It's a 1948 after all and seals don't last forever. '48 makes it an antique.
   / Oil leak
Any idea of cost of repair?
   / Oil leak #4
Your nearest tractor shop should give you a good idea of cost to repair. Do the other side at the same time….😉
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
