oil leak
/ oil leak #1
hillma
pineville, ky
L39 kubota 4x4
Can anyone tell me where I would find the procedure to replace the oil seal on the front wheels on Kubota L39? I am a newby to this forum. I have oil leaking around both front wheels of my tractor. Thanks
/ oil leak #2
Hi, Hillma.
You might have better luck in the 'Kubota Owning / Operating' forum. This leak is a common problem with the L series tractors and updated, improved parts are available. I replaced the seals on my L2900 myself using just a parts diagram from the dealer. It was a pretty straightforward job. About 300 bucks in parts and a couple of evenings in the shop, and I was good to go. Something you might try to save rebuilding is to replace the hydraulic fluid in the front end with 80W90 gear lube. Quite a bit thicker, but still lubes the gears just fine. May be thick enough not to leak.
Do a search on L2900 front oil seal repair. Here's a thread:
http://www.tractorbynet.com/forums/kubota-owning-operating/150420-l2900-4x4-front-axel-bearing.html
2022 EZ-GO ELITE...
HARDEE LR40142 DITCH BANK MOWER (A64278)
HARDEE LR40142...
2017 Ford F-250 4x4 Crew Cab Pickup Truck. (A64194)
2017 Ford F-250...
2012 Jeep Compass SUV (A64194)
2012 Jeep Compass...
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
2017 MAC Half Round T/A End Dump Trailer (A64194)
2017 MAC Half...
