oil leak
/ oil leak #1
hillma
pineville, ky
L39 kubota 4x4
Can anyone tell me where I would find the procedure to replace the oil seal on the front wheels on Kubota L39? I am a newby to this forum. I have oil leaking around both front wheels of my tractor. Thanks
/ oil leak #2
Hi, Hillma.
You might have better luck in the 'Kubota Owning / Operating' forum. This leak is a common problem with the L series tractors and updated, improved parts are available. I replaced the seals on my L2900 myself using just a parts diagram from the dealer. It was a pretty straightforward job. About 300 bucks in parts and a couple of evenings in the shop, and I was good to go. Something you might try to save rebuilding is to replace the hydraulic fluid in the front end with 80W90 gear lube. Quite a bit thicker, but still lubes the gears just fine. May be thick enough not to leak.
Do a search on L2900 front oil seal repair. Here's a thread:
http://www.tractorbynet.com/forums/kubota-owning-operating/150420-l2900-4x4-front-axel-bearing.html
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2012 FREIGHTLINER CASCADIA 125 6X4 T/ANDEM  SLEEPER TRUCK TRACTOR (A67147)
2012 FREIGHTLINER...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2025 66in Swict Bucket Skid Steer Attachment (A64553)
2025 66in Swict...
2020 CATERPILLAR 926M WHEEL LOADER (A65053)
2020 CATERPILLAR...
