oil leak
/ oil leak #1
Anonymous Poster
Epic Contributor
Hi to all i hope the new year starts better than mine, I was doing a little bit of slashing and noticed oil leaking from where the steering meets the top of the gear housing ,on a close look i noticed a small hole maybe a breather hole? Can someone tell why the oil is coming from it. Not sure what seals are in this area , any help please
Barry THE TRACTOR IS A L1500DT
/ oil leak #2
BarryS,
Not much info to go on. /w3tcompact/icons/frown.gif
Make an model would help,how about registering up. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
/ oil leak #3
you have water in your steering box..the only seal is onder the steering wheel.Kubota have this problem...take out the drain plug,get the water out.then put a grease fitting in the hole.and at least cover your steering wheel.
John Deere 350 Sickle Bar Mower (A66408)
John Deere 350...
TIGER MOWERS TRF102-102" REAR FLAIL MOWER (A63276)
TIGER MOWERS...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
INSPECTION (A65583)
INSPECTION (A65583)
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
